I have a customer who has a ZR 800 2001. He had a oil pump problem for a while. Engine did not use any oil, I checked the line, seemed full, I ended up leaving the bleed screw out for about 45 seconds. I removed the oil line to fuel pump and manually pulled over engine, I then visually saw the oil was pumping. Reassembled all components and pump has worked ever since.
