700
My SRX speedo quit yesterday so I pulled the gear housing off the bearing to make sure the bearing wasn't shot. The bearing was fine but the short connector that slides into the axle was twisted off. I believe the cause was becouse I just switched axles and I think there was probably something down inside that caused the connector to be in a bind. Either way, there is something down in the axle now that won't allow the connector to go in all the way.
Here's my question. Is there anyway to get the broken peice out of there with out taking out the axle? Does that insert in the axle press in or screw in and if so how do you screw it out? I think I can shorten the new connector and make it work but if I can do the job right, I want to do it right! Help
