Dave M
SRX500_129 said:what type of airfilters are you using?
the biggest problem with lean mixture comes from the airs way into the carbs.. there is a lot of people that doesent understand how importen this is. the airbox most be mounted perfectly!
HUH ???? please explain..
SRX500_129
Dave M said:HUH ???? please explain..
you really need a explaiation?
I cant explain it in english, i'm sorry.. but i can try:
If you have a leak in the airbox joints (its not exatly a airfilter), the engine WILL run lean on that sylinder because the carbs need a pipe before the carbs intake. the pipe is the deal here, so if you remove the stovk airbox, and replace it with some conefilters, then you could got a problem with the mixture. the best way is to mount a pipe betwin the carb and the new conefilter..
take a look at this picture:
http://webservices.motorsportdealers.com/parts/partImages/YAM/2/05/0063/0006.Gif
the nr 18 is those pipes that brakes down the air and stabilace it way into the carbs so that makes a vacuum inside the carbs. that makes the mixure stable all the way to the top rews..
well.. i hope you understand my explaination..
pull motor split case change seal....renos2 said:how hard is to change crank seal on pto side
Dave M
SRX500_129 said:you really need a explaiation?
I understand..just wanted to make sure everyone was on the same page with the proper information....
renos2
Thanks for all the help Guys get parts today and I will put it back together and start it up then check crank seal with it running
Shafner79
renos2 said:Thanks for all the help Guys get parts today and I will put it back together and start it up then check crank seal with it running
Any update on this since you put it back together????
If a crank seal leak test is good, I would remove the attac
