Weird Idle (bad TPS or TORS?)
MTYooper51
Houghton
After finally thinking I had my Viper figured out I got thrown for a loop. I pulled my carbs off to the side to look at my reeds, which were fine (a buddy had his reeds come apart and wreck his engine). After reassembling everything my sled was extremely hard to start. After getting it started it idled EXTREMELY rough at approximately 3000 rpm. The engine simply bogs out when I give it some throttle to clean it out. I'm thinking I may have possibly damaged either my TPS or carb switch when I pulled the carbs off to the side. What do you guys think?? Thanks in advance.
MTYooper
