Mahoney
OK, I picked up a set of Viper rear shocks. I know I need to buy longer upper transfer rods, but the part # for the limiter straps is the same on the 01 SRX and the 01 SXR.
Are they the same, I read here that they are longer w/ long travel?
Don't want to order stuff I don't need, done plenty of that before.LOL
troyhatt
the 01 has the longer straps already but you need to put spacers in the transfer rods. or get a longer set off a 99. call pioneer performance for the spacers.
JeepJimmy
what you doing for the front?
JeepJimmy
any tips on installing the Viper rear shocks in a 01 SRX. new to me.
troyhatt
The Viper Rear Shocks Will Directly Bolt In . For The Front I Have Olhins And Put Drop Brackets From The Guy From Ebay, I Herd You Also Can Just Flip Your Origional Front Shok Mounts And Get An Extra Inch Of Height In The Front.
Mahoney
I flipped the front brackets and it's fine. I had to grind about a 1/4" off one corner to clear an obstruction, but it does give you almost an inch more.
Mahoney said:I flipped the front brackets and it's fine. I had to grind about a 1/4" off one corner to clear an obstruction, but it does give you almost an inch more.
An inch more ride height but the suspension travel is the same. A step in the right direction if the rear skid is long traveled but flipping the front brackets is not increasing the susp. travel.
JeepJimmy
see Viper shocks listed as Aggressive shocks whats the deal with those are they different then regular Viper shocks??
sgauthier
i've had the rear viper shocks & SXR limiter straps on my 98 for 3 years. i find it took a lot of the smaller chatter bumps out. i also updated it with a newer SRX seat which has more padding. makes a big difference. all i did with my front ohlins is add the 3/4 extension to the end of the shaft. i left everything else stock and i've got a good 1.5-2" sit in and it handles just like it did before the swap.
JeepJimmy
whats the difference between pioneer long traveling stock srx shocks VS Viper shocks???
