Shorting of the water temperature sensor
tyler66665
North Bay, Ontario
I just fixed my electrical problem with my TORS tonight and now I am getting a code of one flash with three quick flashes to follow and it repeats over and over. I have had this code last year and posted it on here. It was suggested to unplug the wires under the water rail and plug them back in. This worked and I never had the problem until now.
I have tried unplugging the wires with no luck this time so I need some suggestions. I have also traced the wires back to the harness and haven't found any rub through.
I can't win!!! :o|
if wires checked out you checked the end plug and up the harness try the senser it's self...
did you check the connector end like we said above? yes you'll loose some
coolant..
ok i see you did..lol
coolant..
Just went back out to the garage and checked the connecter again but still everything looks fine. I will investigate some more tomorrow night. Thank for your help guys!
check with a ohmz meter the contunity from the blue and red wire at sensor to cdi white connector u will find the same wire there and the black wire goes to ground
ok check the blue red wire in white connector at cdi it goes to sensor check for continuity...maybe u have a rubb wire at cdi or broken wire..black wire goes to ground
Not 100% sure what you mean so I check the blue and red wire and the move the meter over to the cdi box and check the wires there?
