Fat Man Clutching :)
Corey9965
Richford, Wisconsin
I am going to clutch my 98 700 with the loaded 8dn-20 package. I am also going to change my top gear to a 22 and keep the 37 on the bottom. I will be running a 50/42 helix with either a green ar red spring. Theoretically from what I have read I should be in the 8500 range when I am supposed to be at 83-8400. Should I order a heavier rivet for the tip right away? I weigh 300lbs suited up and have an M-10 rear suspension with a 1 inch track and 192 studs. Will this kit work for me?
I have a 2000 SRX700 and I weigh about 275 not sure what I weight with all my snow gear on but anyways I have mine geared at 22/39 primary g-w-g spring 8dn-00 with 4.5 rivets both holes and a green secondary and a straight 47 degree helix and this thing pulls really hard
My sled pulls great to about 70-75 then really falls off. I am taking out the aftermarket springs and weights and going with Yamaha stuff so I can get a little more help with the performance. The way I see it is, if you know what you got in your sled its a lot easier for people to help ya.
No factory parts in the clutches. Different springs and weights from an unknown source. Thats why I'm goin with the 8dn-20's. I also have 89a, and 8dn-00. I was thinking either the 8dn-20's or picking up some 8bu's.
