tripple tripper
i have a 2001 sxr 700 i just bought with psi pipes and maxx clutch(secondary) i changed the two bi-metal bushings the other day now it seems to turn up more before engaging(5-6 thousand)
wow i have alot to learn on clutching! the primary has a yellow spring ,secondary has black with green tracer(what should the pre load be?) i did add some washers to get my belt riding where it should be that helped a bit
