00SRXWHERRY
So what do you guys use to clean the engine? Also is it safe to use a power washer on the engine?
I just use a engine degreaser and brush let it soak then hit with a power washer. make sure it's paint safe so you don't tarnish the finish on the tins
under the hood.don't get crazy with the PW.
RJH
Honda brake spray
woofer700
WD40, brakes down the two stroke oil, and you dont have to scrub anything, use a power washer to clean it out. also use it to help stop the rust from forming on the exhaust, i store it that was too so in the late fall, all i have to do is wash it out. very simple and very cheap, one big spray can will do four sleds.
woofer700 said:WD40, brakes down the two stroke oil, and you dont have to scrub anything, use a power washer to clean it out. also use it to help stop the rust from forming on the exhaust, i store it that was too so in the late fall, all i have to do is wash it out. very simple and very cheap, one big spray can will do four sleds.
wd40 eats rubber though, alot of rubber to be eatin under that hood, lol!!
Use engine degreaser or simple green. Power wash and dry. If you don't have a power washer bring it to the car wash without the hood on it rinse it out.
