stumpzilla
Guest
1st post.... please be gentle.
I searched, but didn't find if there was any way to determine if the '98 crank update had been done other than running the VIN or just taking the guys word for it (and he doesn't know anyway). Any thoughts or other tricks?
Thanks.
Thanks.
seca
go to your local yamaha dealer and give them the vim # , it should show every bit of work done on it at a yamaha dealership.
YAMMIEGOD3:16
MOTOR LOOK LIKE ITS BEEN APART. 3:16 (yammie tony)
2strokinit
Luck
Good luck, they ran mine and couldnt even tell if it had or hadnt. It does now as I rebuilt.
srxhair
they could not tell if mine was done either, i got 1 season and got the vibrations in handlebars, it was only about $600 to repair at the dealer 2 years ago and i removed and installed the motor but check with the dealer anyway
2strokinit
600.00 Doh
I pulled engine down, removed crank and took it in. Cost was 100.00 and it included checking phase and runout.
stumpzilla
Guest
How many km's on it when you got "the shake"?srxhair said:they could not tell if mine was done either, i got 1 season and got the vibrations in handlebars, it was only about $600 to repair at the dealer 2 years ago and i removed and installed the motor but check with the dealer anyway
This particular 98 has 9000+ km's, so is it safe to assume that the crank has been done?
srxhair
about 3000 kms its a mountain srx i believe the studded srx's went early but 99% of srx's were done by yamaha, mine only had 2300 kms on it when i got it 3 years ago
