..SNAKEBIT..
the manifold flanges are missing? you need flanges to bolt the the cylinders when you remove the y-pipe
my CPR's have 3 silencers not 3 into 1, might try looking at the SLP site?
I dont know but they might be SRX pipes?
how sure are you on that turk...they dont look like the viper ones on slp's site...and snakebit dont worry flanges are with them
Those are slp pipes. Maxdlx
Yamaouch08
look like SLP pipes to me too!
If that's the case what are they worth?
with the poor economy and hi price of gas, I'd say be a hard sell. They used to fetch 425 to 450. I'm guessing 375 will be tough right now. Maxdlx
Thanks guys.
Got them for $260 shipped. Gas is a lot cheaper now than it was 1 year ago.
mopar1rules
i think they are actually speedwerx. if you look at the slp pic of the viper pipes, one of the pipes actually plugs into the side of the silencer, where these don't have a entrance like that....here's some links to compare the pipes....also, in the speedwerx pic, look at how the mag pipe wraps around and then look at the slp pic, at how it isn't like that....
slp pipes...
http://www.startinglineproducts.com/catalog.cfm?pageID=detail&catalogID=5&catID=39&productID=564
speedwerx pipes...
http://www.m-performance.com/Sidor/dyno_yamaha_viper.htm
sxlover...i would be willing to bet the farm they are speedwerx.
slp pipes...
speedwerx pipes...
ExpertXViper
Those ARE NOT SLP's unless they made 2 diff. designs that Im not aware of. Contact SNOCROSSER on here he was running Speedwerks on his old Viper.
They difenetly look like SLP Viper pipes, but the can is wrong. If they are then that can will not work. Are the ends of the pipes (where they go into the can) rounded like a ball, or flat with a colar?
If they are flat, then I thin kyou have speedwerx pipes there.
ExpertXViper
YamerDown said:They difenetly look like SLP Viper pipes, but the can is wrong. If they are then that can will not work. Are the ends of the pipes (where they go into the can) rounded like a ball, or flat with a colar?
You might wanna look as those pipes I sold you cause they didnt look like that. As Mopar said SLP pipes make a tight curl where they enter the can. Where with these pipes the curls are on the can and not on the pipes.
I was wondering about them being speedwerx, but figured with 3 people sayin SLP's thats what they were. Didn't know if they had a design change or what. I'll look at them more closely when I get them because the seller said there was a stamp on the pipes.
bravo-guy
seen the pics of speedwerx pipes, they look the same, i'd say thats what they are,
I look at them every day and smile. Good point though I didn't read mopars post that closely. Yes two of the SLPs wrap back 180*, but the third does not and is very similar to the top pipe in the posted picture which is what lead me to my conclusion.ExpertXViper said:You might wanna look as those pipes I sold you cause they didnt look like that. As Mopar said SLP pipes make a tight curl where they enter the can. Where with these pipes the curls are on the can and not on the pipes.
Anyway, I agree he has a set of speedwerx pipes there.
