srx billet polished brake rezzy
amatosrx
VIP Life Member
byron center mi
here is my brake rezzy i polished up turned out nice. i also had a custom hand grip warmer knob made. :bling:
also had a cap made for my oil tank. the ring on the starter key is from a yamaha nytro :bling:
bravo-guy said:
How hard was it to change the stock headlight to the newer 2000+ headlight/winsdhiled/gauge???
changing the actual headlight and pod are easy but you will need the new harness and change your stator cdi and all of the rest of the eletric. also the engine case is differant where the stator mounts.
