progold
Awsome unique and custom ,i think i will hang on to my viper for a few more years and start to trick it out ,great job looks great.
PhatboyC
Now don't go adding to much weight with all the metal polished parts. You go slower.
i always cut the weight somewhere when i add some.PhatboyC said:Now don't go adding to much weight with all the metal polished parts. You go slower.![]()
bravo-guy
is that a pre-2000 SRX???
98 srx 700bravo-guy said:is that a pre-2000 SRX???
bravo-guy
How hard was it to change the stock headlight to the newer 2000+ headlight/winsdhiled/gauge???
changing the actual headlight and pod are easy but you will need the new harness and change your stator cdi and all of the rest of the eletric. also the engine case is differant where the stator mounts.bravo-guy said:How hard was it to change the stock headlight to the newer 2000+ headlight/winsdhiled/gauge???
