Blue Devil
I am in the process of completely doing my sled over (BODY AND MOTOR).What all can I do to the motor to add hp with mostly stock parts.I remember seeing something about adding a extra base gasket and someting about drilling the hole bigger in the pistons.can someone please give advice on what to do to help my sled go like...............
Brad
- May 23, 2003
RPC / Reichard's Performance Center has a what they call a 700 srx cheater kit for $429. PN#6840 it's for the 98-99's , base gasket head and piston mod and clutch kit
there number is 262-251-8472 / www.rpcracing.com . If you decide to do the piston mod and stuff just make sure you use yamaha pistons and after get them ceramic and molly coated it;s worth the money and peace of mind
98srx6
The first thing i would do if i were you is clutch it via the tech page, make sure clutches are aligned, and clean and adjust powervalves.
MrSled tells some of the mods that you can do to this sled in this thread:
http://www.totallyamaha.com/forums/showthread.php?t=5711&highlight=
