viperkuku
- Jun 17, 2004
I bled the air out of my coolant system on my viper the other night. My only question is that I couldn't get any coolant to come out of the bleed hole by the carb heater shut off valve. I bled the heatexchanger with the back of the sled in the air and then warmed the sled up to where the heat exchangers were warm and did that proceedure again, then I pulled the bleed screw out by the carb heater shut off valve and I couldn't get any coolant to come out? What should I do?
keep trying or pull the cap and make sure you have anti freeze...
Make sure the valve is open, otherwise it air locks. Maxdlx
