What is the best "product" to use to combat E10?
If you are running around in Ontario Canada, and I would suspect northern Quebec, it would appear that Premium fuel from a variety of gasoline suppliers does not contain any ethanol.
Premium grade gasoline does NOT contain Ethanol
Shell 'V-Power' Premium gasoline (also Beaver brand premium)
Petro Canada SuperClean
Esso Supreme (Imperial Oil)* (also Seven-Eleven premium?)
Ultramar Supreme
Surprisingly though the Sunoco 94 octane stuff is 10% Ethanol. (Dammit I just put 20 litres of that into the sled)
But. The above rests on the assumption that the information here http://www.greenhulk.net/forums/showthread.php?t=66682 is reliable. Don't see why the info would not be good but..... might not be.
The posts seem to be from 2008, stuff can change but I have not heard anything in the news or other sourses.
Have a read of the post where the link takes you, informative as far as where to get gasoline sans ethanol.
The guy that started the post contacted the gasoline suppliers to get the goods on which gasoline offerings have ethanol and which don't. If you were really interested in knowing each of the gasoline suppliers here in Canada will answer questions if you ask.
we just learned that when running ethenol gas in stuff, you should be dropping 1 heat range on your plugs with a stock motor. with modded intake and exh it should be dropped 2 steps colder. brother just attended a seminar put on by ngk and he asked this question specifically as he had engine failure last season.
