larger wheels
bobsiding
wi
hey Guys, i ran across some polaris 5 3/8 wheels. is that too big to run? ive been reading to install5.35 wheels these are a tad bit larger. what do you think? thanks awsome site
I run the larger wheels 5.625 from PPD purchased from Whal Bros. Stock is 5.125 so we are talking about .25 inch farther the track is pushed away from the sliders. Your skid will run much cooler. They work great.
I thought someone on here had a problem with them touching each other on the front outside skid rail where there is two on each side.......but I am not sure!!
i run the polaris wheels and they work great they are close but don't touch.
i measure them again and theyre 5 3/8 , should come out to 5.375, dont know too much about polaris wheels. thanks awsome site
River runner is correct. The wheels will touch if you are planning to run the 5.625 sized wheels. I moved the mounting block about a half an inch and drilled two new holes. When my group is riding in spring marginal conditions my skid is noticeably cooler with snow packed all over my skid with every one else burning hyfax and skids looking very dry. Big time temperature difference.
