Primary and Secondary Clutches for a 90 Phazer?
Daring
Idaho
It is my understanding the clutches on 92 and newer Phazers are better and easier to maintain then on my 90 Phazer. Can I just buy 92 and newer clutches and install them or will I have to have the newer motor and jack shaft?
You can simply swap both the primary and secondary dont, forget the wider belt. The switch over was mainly for performace gains and not a reliability issue.
Thanks Chuck. I had heard that the pins in the older models floated where the new ones are bolted. The bolted ones did not wear as much.
Do you know if Pogos from a Vmax 4 will work on the Phazer? I thought they were bigger in diameter.
