Primary and Secondary Clutches for a 90 Phazer?
Daring
Idaho
It is my understanding the clutches on 92 and newer Phazers are better and easier to maintain then on my 90 Phazer. Can I just buy 92 and newer clutches and install them or will I have to have the newer motor and jack shaft?
Thanks Chuck. I had heard that the pins in the older models floated where the new ones are bolted. The bolted ones did not wear as much.
Do you know if Pogos from a Vmax 4 will work on the Phazer? I thought they were bigger in diameter.
