Need a wiring diagram!
700
Big Falls,MN
As long as my engine is out of my SRX I'm going to put electric start in it. Everything is pretty straight forward but since SRXs didn't come with an electric start option you can't just plug the wires in! I can hook up the ignition switch easy enough to make it start but I need to know for sure where to splice in the charge wire for the battery? If I could get someone to provide me with a wiring diagram (found in the service manual) for any sled with the option of electric start I can compare it with my SRX diagram and figure it out. Or if anyone has done the conversion successfully already just tell me where you hooked the charge wire into. ;)! Thanks, Aaron
p.s. I plan to take pictures and add an article to the Tech Pages when I complete the install.
hold on i can post my '98 xtc diagram of the starting sytem,may help you
but not beeing a tripple i don't know...
this pic is just the starting circuit,the other pic wouldn't scan post good because it's so small,if you want give me your eamil and i'll send it that
way see if it helps.
I got the diagram via Email and I can read it fine. This should do it for me, but if anyone has done this conversion please give me youre input.
