weight transfer
hawke
redford
I have the transfer rods but I am looking for more transfer? Any help will be helpful
Thanks Jason
mountain performance transfer enhancement kit... like night and day.. gets rid of the transfer rods completely...
I have 1" right below the adjuster. My limiter straps are out as far as possible.
I am starting to question if it's transfer or hooking up.
Thanks Jason
Couple things you could try.
Loosen the front springs off to put some sag in the front end.
This will put weight on the front of track.
Tighton front skid spring.
This will put weight on the front of track as well.
Take some pressure off the rear spring or adjust the fra to a differant setting.
The bottom setting might work better than what you have now.
