Couple things you could try.
Loosen the front springs off to put some sag in the front end.
This will put weight on the front of track.
Tighton front skid spring.
This will put weight on the front of track as well.
Take some pressure off the rear spring or adjust the fra to a differant setting.
The bottom setting might work better than what you have now.
