ebayfreak
hey guys, just recently mounted on srx a studded 1" track with 1.0675 studs. I have a slight rumbling noise or vib from underneath. Is this normal? My track has good deflection and have stud protectors installed. thanks!
ebayfreak said:hey guys, just recently mounted on srx a studded 1" track with 1.0675 studs. I have a slight rumbling noise or vib from underneath. Is this normal? My track has good deflection and have stud protectors installed. thanks!
Depending on the type of 1" track, the lugs may be hitting the front HX guards. Some guys just run it and allow the lugs to ware away. Seemed to me this could generate a lot of heat so I cut about an 1/8" off the tip of the lugs where they contacted the guard (both sides).
ebayfreak
i'll check that, but i have not noticed any wear on my track lug.thanks!
It is probablly the studs going over the wheels. Mine does it too
ebayfreak
checked up front ,nothing noticeable rubbing so it's probaly the wheels as you say. thanks guys!
