Okay, an update on this whole thing lol. Yamyrider gave me some specs on the stator and pick up coil. The pick up coil tested at 199.3 Ohms so Its alright Im assuming because 200 Ohms is the spec. Now I ran into a problem testing the windings in the stator. Im not quite sure How to test them, its a 3 wire plug and I dont know what pins to test between or if thats even how you test it properly (im assuming it is) When I test between the pins Im getting a resistance of 0.7 Ohms which is way off because the one spec is 85 Ohms and the other is 400 Ohms. If anyone has tested one before could you please let me know how to go about testing it properly. Just wanna check it all before I put it back together, saves me tearing it all apart again.
Also, I pulled the carbs off, went through them with a fine tooth comb lol, no signs of dirt or anything.... needle and seat are fine in all 3 so its definately not in the carbs. I pulled the top covers off them to and checked if everything was alright on top of the needle and it was.
Still dont know what to think, I wanna test the stator, put it all back together and try it and see what happens thats about all I can do I guess.
