valin
Of course the PTO pipe is cool. It is not burning the fuel in that side, therefore not building any heat. Follow my suggestions and start troubleshooting it. You'll find it. Check your wash. You'll know if it's leaking coolant. I"m still betting on a broken reed.
harness racer
x2 valin
valin said:Of course the PTO pipe is cool. It is not burning the fuel in that side, therefore not building any heat. Follow my suggestions and start troubleshooting it. You'll find it. Check your wash. You'll know if it's leaking coolant. I"m still betting on a broken reed.
do u think a bad reed will really effect on top end
valin
Enormously. For example, my 270hp race sled would only ran 88 mph due to having one of the four V-Force pedals missing in the center reed block. If they are broken, or missing, it won't make any power.
harness racer
It Does Not Only Happen To V-force ,i Have Seen A Broken Reed On A Stock Cage , Last Week As A Matter Of Fact ,
valin said:Enormously. For example, my 270hp race sled would only ran 88 mph due to having one of the four V-Force pedals missing in the center reed block. If they are broken, or missing, it won't make any power.
roger 10-4
madpat
I,m going to check it in a couple of hours.i have a extra stock reed i could put in if every thing else checks out.Thanks for all the input i really appreciate it.
