mopar1rules
800vmax4 said:When I built my 2002 SRX engine I removed the stock pistons,cylinders, + heads and set them aside untouched so I could always return the sled to stock
I initially used a set of 98 heads and cylinders that I cut + ported[before I installed the"Peak" head]
I cut .035" off the mating surface and .030" off the squish band of the 98' heads.
Results:
-installed squish: .058" [stock with my 2002 heads was .061" ]
-installed cyl head volume: 20.75cc[stock with my 2002 heads was 22cc ]
-new comp ratio: 12.2:1 [stock with my 2002 heads was 11.5:1]
thanks 800vmax4!! those are the answers i like....the ones w/specs/results.
i'm assuming you used 3 base gaskets too?
