track not flat on ground
Stock track with 96 studs down the middle. I am going to set the center shock with little preload and adjust the rear shock to get my 50/50 gap. I already have the fra in the top postion and will go from there. Thanks guys. I have been looking at all the threads and just want to get as much input before I start working on it.
That should get you to where you need to be as far as gap goes,let the preload off the rear shock until the 50/50 gap shows.Where your son goes 160 with all his gear on you definitely want the FRA in the softest position and it may even be beneficial to have the shock(s) revalved for his weight if your going to keep the sled.
After this year I am going to send the shocks out to be done over for his weight and riding style. Thanks for the help.
