Yup, the 7,897th SR540G made for the 1983 model year to be exact. I would suggest the Comet 108-EXP. I would check with Rich, but if he can't help you then any of the mail order houses usually handle the Comet 102-C, 108-C, and the 108-EXP, and will package one up with the weights already installed.
Note: Be sure to check to see if you need the clutch with an oil pump drive gear on the back of the fixed sheave. Some are seperate and some are fixed to the clutch.
In any case I believe that you will need the following for the 108-EXP . . .
1 Comet part # 217506A (108-EXP with 30mm 1:10 taper/-.140"
3 Comet part # ??????? A-1 (cam arms - qty 3)
1 Comet part # 207877 (Red spring) or 209677 (Red/Silver spring)
Again be sure to check on the pump drive gear requirements.
