srx98jj
will a broken ring cause a melt down
mopar1rules
a broken ring won't cause a meltdown, but it will cause cylinder wall, head, and piston damage....deep gouges and scoring. possibly crankbearing damage too, but usually just the top end gets the damage.
usally a lean melt down will cause a broken ring....lol
YAMMIEGOD3:16
TELL YA WHAT IT WILL CAUSE IS MASS DESTUCTION. 3:16 (yammie tony)
srx98jj
ok , heres the deal. trying to figure out what happened. put new power valves in and adjusted , remember ? thanks daman !! . it was running balls out. kicking the crap outta f7....went to mich , ( im from youngstown oh ) rode 5.6 miles and she burned up #1 cyl cluth side burnt the piston past the ring gland the other two look new ... this motor hasnt been apart 12,000 miles. i take meticulous care of it .....could it be the power valve gaskets cuz i didnt replace them ?? just wanna make sure i correct the prob
srx98jj
one more thing ,...absolutly no damage to the head
happend to me one time .... power valve hit the ring and broke the top piston over it ...
srx98jj
any ideas about the gaskets ? daman ?
hereismylife
ok you said you did not have this engine apart for 12,000 miles right? Well from what I was told and from what I read here. You are to change your rings every 3000 miles. This might be a reason they let go... just a though.
No that pv gasket wouldn't have caused that,bad gas(too low of octane)srx98jj said:ok , heres the deal. trying to figure out what happened. put new power valves in and adjusted , remember ? thanks daman !! . it was running balls out. kicking the crap outta f7....went to mich , ( im from youngstown oh ) rode 5.6 miles and she burned up #1 cyl cluth side burnt the piston past the ring gland the other two look new ... this motor hasnt been apart 12,000 miles. i take meticulous care of it .....could it be the power valve gaskets cuz i didnt replace them ?? just wanna make sure i correct the prob
wrong jetting/air leak is what happend,waaaay over do for rings @ 12,000
pistons are probably outa spec now.
chilli
wow, I just did my rings at 15,000KM, guess I was over due too!
Thats why you had all them problems.
J/K
J/K
