what are the best aftermarket reeds for 98 yamaha srx ?
staggs65
from what i've read here, stick to the stock yamaha reeds
Is this for a stock sled? if so OEM are hard to beat,focus on clutching if your looking for little more. $.02
9801srx
x2 ... the oem reeds are excellent unless your engine is going to make 170+ h.p then aftermarket reeds might gain you a bit more.daman said:Is this for a stock sled? if so OEM are hard to beat,focus on clutching if your looking for little more. $.02
YAMMIEGOD3:16
RUN YOUR STOCK REEDS, YOU MAY CONSIDER CHANGEING PEDALS TO CARBON FIBER BUT STOCK REEDS WORK. 3:16 (yammie tony)
ok now to my second ? whats th best clutching for 98 srx?
staggs65
the clutch guys are going to want to know what ur current setup is (primary spring, weight, secondary spring wrap helix) what your rpms are from stop to full speed, maybe your weight and what your intended use, for starters
YAMMIEGOD3:16 said:RUN YOUR STOCK REEDS, YOU MAY CONSIDER CHANGEING PEDALS TO CARBON VIBER BUT STOCK REEDS WORK. 3:16 (yammie tony)
X2...I am a big fan of the Carbon Fibre reeds in the stock cages, if the rest of the engine is basically stock.
staggs65
what brand? where can u get em, how much $, what do you gain?
might be interested in trying if the bang for buck is worth it
mopar1rules
800vmax4 said:X2...I am a big fan of the Carbon Fibre reeds in the stock cages, if the rest of the engine is basically stock.
yep, carbon tech petals (carbon fiber petals) work well for little $ on the stock cages. parts unlimited sells them as well as some of the site sponsors.
Hi: try http://www.carbontech.com/snow/yamaha.htmlstaggs65 said:what brand? where can u get em, how much $, what do you gain?
these worked very well on my 1999 SXs even with Bender pipes ect
staggs65
thanks, mopar/800vmax4, got one pedal starting to wear at tip, so i gotta change em one way or another
sorry xviperx7 for hijacking, post ur clutch info and you'll get the help u need
iceman
I agree with Yami god the stock reeds work real good and last forever but that said I run carbon tech now cant really say how much better they are seems a little crisper corner to corner may be all in my head,clutching is better time spent.
