blew by you
I need to remove the primary sheave cap to install engagement shims behind the primary spring.I want to do this with the clutch still on the machine.Do I need a spring compressor or can I squeeze the cap on with my hands and get my buddy to screw the bolts in? (1999V-max500SX)
You should be able to did it if it's a stock spring. If you have trouble you can try using long bolts to get it started, then put the stock ones back in.
YAMAHIZAL700
its simple you can do it by yourself
