nos on a 81 srx???
cujo49868
U.P.
i m looking at building a 81 srx to run 660'-has 240 studs "77" steel sleeve cylinders runs about 130 pounds of compression 44mm carbs...have a boss noss setup for duel carbs ...that would make this thing a super sleeper! is there anythign special i would have to do? will a pro balance wysco kkit handle nos? will this motor period handle a 30 hp shot?...if anyone has anyother idea for a hop up?? any info would be great....thanks!
DRP has a lot of experience putting NOS to that engine. I don't see a problem if it is healthy.
the 440 should have a 20mm tapered shaft? would like to put a comet on it-there are so many clutching options when you go that route..does anyone know if wysco's will take nos? lol i m sure u can tell i m definatly new at this...thanks guys-
