98 srx trailing arms
xviperx7
Wiscasset
taking off trailing arms what is the procedure for taking off the trailing arms on a 98 yamaha srx? and anyway have a set for sale for a reasonable price?
super simple jack the front up off the ground remove ski,remove tie rod bolt remove sway bar bolt from ta then both radius rod bolts then shock bolt then ta rear bolt by the tunnel.
