harness racer
LOOKED BACK IN THE NBSSR ARCHIVES AND THE FASTEST I SEEN FOR THE 600 CC CLASS / 2000FT TRAIL CLASS. WAS 109MPH BY A FIII. IT WOULD BE AWSOME IF WE CAN BEAT THAT THIS WEEKEND WITH A SRX 600 , BUT THE CLUTCHING WILL HAVE TO BE SPOT ON .REDUCING DRIVER WEIGHT FROM MY SKINNY 220LBS ...OK 229LBS TO 115 LBS. IM A LITTLE WORRIED ABOUT AN OVER-REV ? DYNO'ED THE MOTOR AND IT MAKES POWER BETWEEN 8350 AND 8500RPM
600SRX
HERE IS WHAT I HAVE TRIED SO FAR , ANY SUGGESTIONS WOULD BE APPRECIATED...EVEN YOU MOD....LOL
#1 SET UP
PRIMARY
B]WEIGHTS[/B
89A10 BASE WEIGHT 48.5GR. ROLLERS 15.5 MM SPRING Y-W-Y 128KG
INNER EMPTY
OUTER 0.9 GR.
TOTAL 49.4 GR.
SECONDARY
8BV71 47DEGREE. YAMAHA GREEN DOT @60
GEARING 23-39
PLUGS BRP9ES AND NO AIR BOX FOAM LEAN MELTED THE PTO PISTON
FROM A ROLL 8400RPM AND CLIMBS TO 8600RPM 111.32MPH/2500FT.
2 HOURS LATER NEW PISTON
AIR BOX FOAM RE-INSTALLED
BR9ECS
A LITLLE WARMER ASWELL
EVERYTHING ELSE THE SAME
FROM A ROLL 7900 RPM CLIMBS TO 8300 RPM 103.04 /2500FT.
#2 SET UP ROLLER ROOSTER
PRIMARY
8DN-10 BASEWEIGHT 41.7GR. ROLLERS 15.5MM SPRING W-W-W 119KG
INNER 4.5GR.
OUTER 2.3 GR.
TOTAL 48.5 GR.
SECONDARY
ROLLER ROOSTER HELIX 39-35 SPRING YAMAHA RED DOT @70
GEARING 23-39
PLUGS BR9ECS = LIGHT BROWN NOT TAN
FROM A ROLLING START 8800RPM AND SETTLES @8600RPM 106.2MPH/2000
600SRX
#1 SET UP
PRIMARY
B]WEIGHTS[/B
INNER EMPTY
OUTER 0.9 GR.
TOTAL 49.4 GR.
SECONDARY
GEARING 23-39
BR9ECS
PRIMARY
INNER 4.5GR.
OUTER 2.3 GR.
TOTAL 48.5 GR.
SECONDARY
GEARING 23-39
