YAMAHIZAL700
I used to have one on my inlaws computer but it got deleted on me. My email is holbs10@yahoo.com thanks. I am puting the bottom gear back in and cant remember for sure if the flat side points out or in towards the drive shaft. By looks alone Id say it lines up better with the flat side in. Any help would be great. I dont want to put pipes and everything back to find out i am binding.
Corey9965
The flat side goes out. It looks decieving. I put the flat side in cus it looked better and scarred up the cover.DUHHHHH.It will look better when you tighten it up.
I answerd you in your other post,try not to double post.
YAMAHIZAL700
Thanks guys. Daman, Sorry bout the double post, I tend to go off on a ramble from time to time.
i just find its hard to keep track and help when there's multi-posts on the same issue is all.
YAMAHIZAL700
No problem. On a side note this thread is dead. Someone sent me a copy so who ever you are I thank you.daman said:i just find its hard to keep track and help when there's multi-posts on the same issue is all.![]()
You are welcome
YAMAHIZAL700
i was thinking Max would be johny on the spot.
