Summer storage
djrascoe
Tampico, IL
Im just a lil curious here to see what my best bet is. Am I better off using satbil in my fuel for summer storage, or is sea foam a better choice. I used to use stabil, but then I got out of sledding for about 5 years. Since I got back into it last year, I've started using Sea Foam. What is the better choice, is one better than the other, or is it just basically user choice?
Just my opinion. My Dad (an A/C mechanic for 17 years) swears by Stabil. I used Seafoam in my Cougar last year. First ride this year-boom.Took out piston skirt. I don't know maybe coincedence. I am using Stabil in my first Yamaha this year. Like I said just my 2cents.
You need to get all the fuel out of these carbs and tank. It it has a plastic tank store it empty if it has a metal tank store it full......plus you do not want your filter to set in the fuel all summer........... here is my post from many years ago.....
Snowmobile Summer Storage
Start sled and warm it all the way up.
Drain all the gas out of the tank. I use a siphon into a 5 gal gas can. Good rule is if it has a plastic gas tank drain it dry, if it has a steel tank fill it up so it does not rust.
Start sled and run it until it stops, use the enrichener as it starts to die to keep it going.
Attach your fogger lines into the carbs. On the newer triple motors you can go in at the carb boots right into the carburetors. If you have a Phazer you can pull off the small rubber plugs that cover the brass tubs that are on the intake boots, you can then put your fogger lines over the brass tubes. If it’s a twin with the boost bottle you can remove the boost bottle and make two plugs that will fit in place of the bottle and drill a hole in each one for you fogger line.
Start spraying the fogger and start the sled. The sled will run on the fogger. Use the throttle just enough to keep the sled running. Run it until it is smoking well and let the motor slowly die as you are still spraying.
I use silicon spray all over every thing, track, bogie wheels, seat seams, hood straps (leave em unhooked), wiring, hand grips, basically all the rubber stuff.
Grease the suspension. Some people will loosen the track.
To keep the mice out put steel wool or a dryer sheet up the exhaust outlet. Put tape or a dryer sheet over the air box intake, maybe through one under the hood too.
When getting ready for that first ride of the new season, put in fresh gas and pull and pull and pull. After you have all that fogger cleaned out, install new plugs or at least clean the ones that are in there.
I don't think I can stress enough about getting all the fuel out of the system for the summer, I had worked at a dealership several years ago for several years and I cannot even begin to tell you how many carbs I have cleaned because people let the gas set in the carbs all summer. Then they wonder why the sled won’t run right. Same with bikes over the winter. The jets and passages in the small carbs are not very forgiving and the gas goes bad very quickly.
Tod
I've had good luck with stabil since 1980. sea foam seems to work to but
stabil that's it's main purpose is to keep fuel fresh. Oh make sure you fog too.
