1999srx600
Hi, I have a 99 SRX 600 that I am converting to a 700, but need help with the clutching. It has an aftermarket helix on the secondary, all it has on it is 122 followed by a degrees symbol, and a black spring. The primary has an orange spring, and the weights have only one threaded hole in them lengthwise from the tip to the base. Does anyone have any idea what make these clutch components are, and where I can get some info on what to change for the 700? Any help is appreciated.
Jaret
Jaret
RIVERRUNNER
Well I can't tell you what they are but if you were running they in the right rpm range 8300 to 8500 before.....You are going to have to change the helix and springs and weights completely when you go to a 700! What do the weights weight?
edgeracer1
Sounds like the Bender racing grass drag clutch kit with there QAW weights.
