SRX lost her snort at wide open throttle
Yamerhammer
Marinette, WI
My 01 srx was a really fast sled but towards the end of this season it is getting beat bad by ditch pickles. I want to say it is a clutch problem. The plugs are nice cardboad brown and i had already cleaned the carbs on it this year. If a peg it wide open she bogs at about 6000, 7000 rpm. If i barley use the throttle and let it ease into shifting it seems fine but as soon as i peg it it bogs down. It feels like it won't shift right. Never has had any clutch work done on it. Not to sure what to look at first. Any input would be great.
yes definetly rebuild your clutch mine did the same thing until i rebuilt it my rollers an bushings were shot an it was a completely different sled after that.
Clutches, drive bearings, chain, skid bearings, etc. like said above, and also check power valves too.
In addition to the great suggestions above...
clean ,sync,adjust carburetors
check compression
refresh top end new rings/seals
clean and adjust power valves
