I need some help. I picked up an srx motor that has already has viper cylinders installed. I will be putting this in my viper and running it single piped(stock pipe) My probloem is how do i plumb the coolant hoses with an srx style head? Or do I have to run my viper head?
harness racer
Come And Pick Up The Hoses Off The Chasis If Need Them To Make It Work !!
The guy that removed the motor cut the hoses. doh!
I am just checking to make sure that i can plumb it the same as the viper since srx the thermostat is on the head and viper it is seperate from the head.
05mtnvipermod
its the same plumbing, if you have viper cylinders than use the viper head.
It is in the sled and running with srx heads and coolant rail and no mods to any of the stock viper hoses(so that when i get the viper crank back the viper motor will drop back in).
Good news in the short test run is pulls like crazy on the bottom. But only seems to rev to about 8000rpm with hc 40-10's only weight in the heel and a 48-40 helix. Gonna do some better test runs tomorrow and do some clutching changes.
Now where is that damn camera for pics........
