just bought a brand new kimpex shotgun 1.25 track for my srx wanted to knwo the installation process and if i can run studs? thanks
SWEDE
Go to the technical section theres a full writeup on track replacement with pictures.You can't run studs on that without switching to eight tooth drivers.If you go without studs you'll want to remove your tunnel protectors and front heat exchanger protectors as well for adequate clearance.
