OnDaTrail
I was wondering if there is a way to repair an oil pump on the SX's or do you just have to bite the bullet and replace it with new, $220 in my case. Mine has taken to very high output, like 20:1 all of a sudden.
You would think that you could get it off, but the lower mounting screw is just opposite a motor mount. I worked on it for about an hour last night and will resume this evening. I think I need to make a custom allen wrench.Nicko said:I have a 99 sx with the same issue..I'm going to get a new one this summer, I'm almost sure you can take the carbs off and it will come out.....I don't see how you have to pull the motor to replace it....
Nick
JohnnyQuest said:Oil pumps have NOTHING to do with the brand of the machine! Oil pumps are made by manufactures such as Mikuni..... Just like carbs and fuel pumps either Mikuni or Keihin! That would be like blaming a carb or fuel pump failure as the fault of the sled maker!? You're better off just getting a new pump.
