lost tack and gas gauge??
teamyamaha
rhode island
Website
www.lubedealer.com
hello sled ran, worked perfect 1 week ago fired her up today after putting tripple pipes on and i lost the tach and gas gauge? i looked at the wires seemed ok?checked connections,ok,gauge is good tried 2 of them.any ideas??or what color wires run these 2 peices that i can trace?thanks in advance
If this happened after running with the tripples I would double check the wiring up to the gauge pod.. I'm betting you melted a couple wires with the new pipes...
The tach and the gas gauge use the dc circuit on the single headlight sled. That is why I suggeted the smoothing condensor. It acts like the battey in an electric start sled. W/o battery in an electric start sled both gauges go baty.
