TRIPLESWILLNEVERDIE!
Anyone have a good jetting setup for PSI pipes on an otherwise stock 700MM for 3000-6000ft? Not sure if these pipes are the Stockblaster, Modblaster or high alt. pipes. They have a 1and 1/8" stinger outlet on the pipes. I have never messed with PSI's on a MM but have heard they work OK.
stockblaster
ilot-55..
fuel screws-2 turns
slide- 3.5
NOZZLE-q-8./.q-4 /q-4
needle-2nd/3rd/3rd pos. 6dgm-05
main jet-137.5/137.5/137.5
fuel screws-2 turns
slide- 3.5
blackford81
what is the peak rpms you should hit with triple psi pipes and stingers.
Are those jetting specs with or without the air shelf removed?
