ExpertXViper
Whats the best and easiest way to remove the Mag and Stator? I dont feel like buying a tool for a one time deal. The 2 arm puller I used on my 98SRX crank worked fine due to the amount left in the cases, whole different story with the redhead. Any help is much appreicated.
tedgoesfast
i have a puller set i use if you lived closer you could use it
taylzee
A 3 bolt steeringwheel puller for $15.00 @ auto store works great for flywheel. You shouldn't need a puller for the stator.
ExpertXViper
taylzee said:A 3 bolt steeringwheel puller for $15.00 @ auto store works great for flywheel. You shouldn't need a puller for the stator.
Thanks alot, thats the answer I was looking for. Im glad I work at a dealer so I dont have to spend any money.
xtc700jeff
That is the ticket , used long bolts with washers and it came right off mine.taylzee said:A 3 bolt steeringwheel puller for $15.00 @ auto store works great for flywheel. You shouldn't need a puller for the stator.
ExpertXViper said:Thanks alot, thats the answer I was looking for. Im glad I work at a dealer so I dont have to spend any money.
I've got two if you need to borrow one. I'm in Dearborn during the day.
I hate when I forget I have something and buy another.
