myamaha
I just bought a 1998 srx mountain 700 and don't know what weights I should have. It has a comet 108exp clutch. I put a 51/43 helix and silver spring in it. I'd like it to jump when the clutch cuts in. I just mostly play around in the deep snow but still want it to be fast. Also should I gear it down or up and how much it's stock right now at 21/39.
I have a MSRX. That gearing is OK for flatland riding. Too much spring in the secondary...go to a green at 60. Sled should run at 82-8400 rpm. Go to heavier weights to bring rpm,s down. 2 grams is roughly about 3-400 rpm,s either way.
myamaha
myamaha
Is a thunder shift kit good for better lowend snap. Can the comet weights be ground with a notch. Why won't the silver spring be good.
