How to fix the rails?
mtnmaxman600
Wisconsin
I tore my rear suspension apart to rebuild it and found that the mounting hole for the transfer rod wore oblong. One side is worse than the other that is because it was run with the bolt loose. I was thinking of boring out the hole and installing a bushing of some kind or just welding up the hole and redrilling a new hole. Looking for thoughts and comments or any ideas. Thanks Eric
I filled one with JB weld one time. Washer on each side with the bolt installed. Let it set and used it that way for years. Never had an issue. Cost $5 or so.
get a steel piece of spacer the right size for the bolt. Drill the hole out to allow the pipe to fit in, and jb weld that in. Works on Polaris pro x rails. Maxdlx
