Help!!!! viper chain case!!
super1c
Super Moderator
Freeland & Otsego lake, MI
My nicely labled cardboard with my chain case parts got messed up. I figured out were everything belongs except the 2 collars. One is thinner and one is thicker. I know where they go in order in putting back together but which one goes on top and which one goes on bottom. Hope this makes sence cause i'm stuck in a bad way. Thanks guys!!!!!!!!!
Thin one goes to the bottom and the thick one to the top,the gear won't slide on right if the thick is on bottom.
Thanks daman!!!!!!!!!!!!!!! Getting close with this track change. Just havent had much time with work and my daughters softball. And i cant forget to mention the redwings games. I have my priorities this time of year.
I've been a cranky SOB staying up to watch and getting up at 4:00 a.m. for work.
For future reference (you cheated by going to Daman, but he makes it so easy), use a straight edge on the face of either gear to check alignment. I use an 8" steel rule. It was 12" but I had to cut it down to fit within the case.
