Where is it stamped G4T-1?
its not stamped..its engraved.. on the inside between 2 ramps.. was on a 95 vmax 600 if that helps any
Anybody know what Hauck Y helix
1894marlin
Hauck helix angles, provided by Madmatt:
D 51/43
G 49/41
I 47/41
V 51/45
B 54/44
L 45/39
N 45/39
K 45/41--measures 43/37
E 47/43
X 52/47
J 47 straight--measures 45
I have an H what's that one measure????
Post 59:
"hauck "h" which is suppose to be 47/43, measures 45/41"
A couple of bucks
You'll have to ask the man himself. Go to his HOME PAGE.
http://www.totallyamaha.net/forums/members/147-Srxspec
977TP anyone? No name on it. Almost looks like a Bender number, but only 3 numerals instead of 4.
maxx perf I believe 6pt5? Looks to measure 46-31? anyone else had one or know angle?
A couple of bucks
Hauck Y -- 51/45 as per Hauck themselves.
A couple of bucks
....Is a 8bv50 a 45*
and an 8bv10 a 41*
Isn't the first number in the helix indicate the degree.
Does anyone know what the last number indicates?
and an 8bv10 a 41*
A couple of bucks
Never mind, found an answer.
http://www.totallyamaha.net/forums/...between-8bv50-and-8bv51-helix?highlight=8bv50
A couple of bucks
What does the PROGRESSIVE portion of a progressive helix mean. Take for instance a 48/42. Does a "progressive", start at 48 and finally end up at 42? Verses a standard that keeps a 48 degree till half way then change angle to a 42?
yamahamark
Bump
Does anyone know what the angle is on a 8bv80 helix???
48?
Sent from my SAMSUNG-SM-G920A using Tapatalk
yamahamark
Alright thanks. I got a good deal on one just wanted to check the angle.
7F7 helix anyone? Cant find in listing. maxximum?
brianbailey440
9870p 53-45.bender racing power shift clutch kit for 00-01 sx 700 big bore.has anyone actually measured one of these?
mopar1rules
Hauck "I" measured 46/38
mopar1rules
Bender 977TP measures 51/45
