I know that racers and speed run guys will use transmission oil or some such in their idler bearings to cut down on parasitic drag caused by the grease normally in them but has anyone experimented in trail running idler bearings with say synthetic 80W90 in them?The synthetic oil is thinner than regular and should allow the bearing to spin freer plus you wouldn't have that heavy grease in there.The seals should be able to hold the oil in and with a thin film of oil on the races and balls rust should be cut way back and bearings ideally would last longer.
Just some food for thought,been a slow week here.
