srx 700 98 starting problem
kallabalik
sweden
i have just bought an srx 700 -98 that doesnt start, it gets fuel, have good compression and spark, but i think the spark is to weak, does anyone know the values or the measurements that the stator coil would have so i can measure if it works properly?
change your plugs, could be fouled, start on easy stuff first,
are the plugs getting wet ??
i have changed the sparkplugs, they all have spark but it seems week, they seem to get wet and ivè tryed to put som fuel into the sparkplugholes but not a sound,
(sry for my bad english i´m from sweden..)
Have you tried to just barely crack the throttle as you pull on it? Mine would never start unless I did this. Just a thought.
yes i have, i have no disconeccted the contacs that come from the eengine, its 3 contakts, one with 2 one with 3 and one with 5 pins in it, the one with 3 was very black and melted how come? which cables should i measure between when i will measure the ohm value from the stator?
today, i disconected the cables from the headlights, pulled them out from under the engine but i didnt se any real damages to the cables... but before i was going to remove the crankwheel and stator i thougt that i would have to try to pull 5 pulls in the starter,
a little bit oft start gas, 3 pulls then it started!:) and goes great ever after, but if i put in the cables to the gauges and headlight it dies after a while, shortcut somewhere?
a little update for the curius, i got it to run as it should now! an mecanic in town gave me a tip that it could be bad connection in the contact that was black and burned and that it makes sparkes there, so i removed the contact and replaced it and now it runs great! starts 2nd pull when cold...
now im only trying to find som quicrods or i will build my own, anyone knows how much i can take away from existing rods without having problems with the track slipping on the drive wheels?
